DAQCard6024e & USB-RS232 Conflicts?
Has anyone had problems using both a DAQCard-6024E in a notebook computer
that also uses a generic USB to RS232 converter? We've had several
instances in different computers and different USB-RS232 converters where
not long after installing and using the USB-RS232 converter the computer
locks up and will not reboot, even after removing power and the battery!
It does not seem likely that these two devices would conflict but we cannot
find anything else common that would cause the problems we are seeing. If
there is a conflict and buying an NI USB-RS232 converter would solve the
problem then I'd be willing to spend the $150 for the NI converter but I'd
like to know that this will fix the problem first.
(2,473 Views)
Duplicate question. See post at http://forums.ni.com/ni/board/message?board.id=250&message.id=11456#M11456
(2,458 Views)
