DAQmX does not show up in Labview 8.5
History: Got sick of Vista and downgraded to XP SP2. Reinstalled Labview, Measurement Studio then DAQmX 9.4 (downloaded the latest from NI site).
Measurement Studio seems to load DAQmX tasks correctly although I am afraid to compile in case it trashes hours of work. I have no reason to trust that it won't.
Labview just does not recognize DAQmX. It doesn't show up in toolbox. Meas & Automation runs and talks to my USB-6212 so I guess that DAQ drivers must be installed and load properly. But Labview.... N/G. Is this version (DAQmX 9.4.0f1) not compatible with LV 8.5? I don't get it.
I have uninstalled DAQmX & reinstalled it with the same results (none). Please help.
Labview 8.5
Meas Studio 2008
(2,844 Views)
Accepted by walter-donovan
It looks like LV 8.5 tops out DAQmx version 9.3:
NI-DAQ and LabVIEW Version Compatibility (for Windows)
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,833 Views)
Thank you. Thank you. I looked for compatibility data and there's just so much info to weed through, this table you linked to got away.
Labview 8.5
Meas Studio 2008
(2,827 Views)
