DAQmx 9172 and Step Response
I am trying to perform an experiment to find step response and some other properties of a piezo actuator.
What i'm trying to accomplish.
1.  I want to send a voltage of 0 volts for a certain period of time.
2.  After, i want to make a jump to a specified voltage.
I have accomplished steps 1 and 2, but when i go and try to re-run the vi, my AI card initially reads one data point at the jump voltage level.  I tried to fix this by sending an array that would have 0 volts, the jump voltage, and then return to 0 volts but it does not seem to work.  If i restart my cDAQ-9172 and run the vi again, it does not exhibit this behavior.
Does anyone know how to make the DAQ return to a startup condition after the vi runs through its acquisition so that i don't have to restart it every time to get it to work properly.  I have attached the vi and a photo of the front panel that shows the initial pulse reading.
(2,468 Views)
Hi lockesmith,
The behavior you are experiencing is interesting and unexpected since both of the tasks are cleared.  Take a look at the DAQmx Device Reset function; however, I think this may be a bandaid for something else occuring.  What modules are you using and their corresponding slots?
h_baker
(2,446 Views)
AO 9263
AI 9215
(2,442 Views)
