VISA write holding up
Hello All.,
I am using PXI-1033 and inside that I have counter card 6602, I also have Animatics Motor connected to COM 1 and my test units,
Motor control is done using VISA.
test units gives me pulses whenever I run the motor, currently I have 2 test units and each test units gives me compensated and non compensated pulses,
So totally I use 4 counter channels to measure pulse width and pulse count.
I came 2 know that we can use only 3 channels if any DAQ card is in DMA mode, so I changed data acquisition to interrupt mode.
Earlier I used to test only one unit and everything was working fine and I was not using interrupt based acquisition.
Problem started for me when I started testing 2 units, when ever I give RUN command for the motor, motor starts running, but VISA WRITE is not passing the reference to the next VISA API and  because of this I cannot test the other modules as there is device hold up.
Has anybody come across this type of situation?
Message 1 of 1
(2,404 Views)
