Load Error 3
Compiled EXE using LabVIEW 8.6.1 - haven't had this problem before this cropped up for the first time.  I had not changed the build spec.  I had not modified the code that calls the VI that is generating this error.
The subVIs call Ramp Function.vi from the AALBase.llb - The EXE is generating Load Error 3 when trying to execute the Ramp Function.vi
If I take this same exe and run it on a different computer with 8.6.1 installed I do not get this error.
I had removed and reinstalled my LV 8.6.1 Run-Time Engine.
I have performed a Repair of my LV 8.6.1 installation.
I tried including the llb explicitely in the project...
Nothing has worked to fix this issue.
I am able in the development environment to drop and then open and view the Ramp Function.vi from the Functions Pallete.
Any ideas?
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(2,873 Views)
Supposed to be Ramp Pattern.vi in the above post, not Ramp Function.  Sorry about that.
(2,860 Views)
Tried creating a whole new project and doing another build - same error when trying to run the EXE on my PC.
I copied another colleagues LV 8.6 AALBase.lvlib and pasted it over my original one - did not fix the issue.
(2,836 Views)
