datalogger
Helo
The vi attached is supposed to log current vs power.im supposed to see current changes on the front panel
under the current(A) string but it remains zero even when the current setting is not zero.another problem is when i run the vi i get the error message
error7 occured at open/create/replace file
can someone help with this
thanks
(2,610 Views)
I took a look at your application and couldn't really tell what was outputting to your current (A) string (the subVIs were missing). The best thing I could suggest is setting breakpoints and probes to see if the values you are expecting are coming out of the subVI that is outputting to your indicator. Another thing to keep in mind is that the chart won't update on the front panel until the subVI finishes executing. If there is a loop in your subVI, it is expected that the indicator will not update until the subVI finishes executing.
As for the error 7 that you are receiving, what is the file path? Generally that error occurs when there is an invalid file path, but it looks like you are using a file dialog prompt to select a file path. Does it occur the first time your program iterates through your loop or after that? Another thing I noticed is that you open and close the reference to the file inside of the while loop. Generally this is not good programming practice as we would recommend only opening and closing each file once and place the Open and Close VIs outside of the while loop.
Stephanie A.
Americas Marketing Manager
(2,579 Views)
