DAQmx Create Scale doesn't work
Thank Kevin.
Unfortunately it is not a signal variation problem. The same problem constantly occurs whether I create the scale by creating with the Linear or Map Ranges scale.
For this reason I am very very confused.
I try with a battery and I'll let you know.
Thanks again
Fulvio
Message 11 of 14
(1,791 Views)
Good morning Kevin,
I would like to update you.
Last night I was thinking that I could connect the same signal to the first three channels. So I did it and the problem is still there.
Do you have any advices?
Thanks again.
Fulvio
Message 12 of 14
(1,781 Views)
That was a useful test, and now that you showed your *code*, I can see that you're having the same problem as the OP for this thread.  And the solution is the same as the one given by crossrulz back in msg #5 and PsyenceFact in msg #6.
The values you put into Max and Min inputs when calling DAQmx Create Virtual Channel need to represent the *post-scaled* Max and Min values.
So when the raw voltage range is +/- 5V, then:
- when scaling by 100x, wired Max and Min values should be +/- 500.
When you specify the *post-scaled* Max and Min as +/-5, DAQmx is figuring out what raw voltage range to use.  But the device doesn't support a +/- 0.05 range, so it uses the next bigger range it actually supports.
-Kevin P
Message 13 of 14
(1,772 Views)
Thanks again for your answer and for the explanation.
Now it is clear to me how it works.
I simply upload the correct code for the benefit of other users.
Message 14 of 14
(1,758 Views)
