DAQmx Custom Scaling Issue
With the configure channel inside a for loop with shift registers and arrays of min and max is one way. Separate functions for each channel is another.
Message 11 of 19
(1,907 Views)
Darn, was hoping to not have to build anouther array of 32 channels min/max
Message 12 of 19
(1,903 Views)
One more question.
With the code i provided before. on the first iteration, i get the following error:
Error -200088 occurred at Property Node DAQmx Timing (arg 1) in DAQmx Timing (Sample Clock).vi:4730001->main.vi
Possible reason(s):
Task specified is invalid or does not exist.
Message 13 of 19
(1,894 Views)
You haven't provided any code. All that I see is a partial image. Do you have a create task function?
You can cheat a bit by creating a DAQ Assistant with multiple channels and then converting that to a VI. Look at the block diagram.
Message 14 of 19
(1,887 Views)
Opps, sorry
Message 15 of 19
(1,880 Views)
Sorry, I'm away from a pc for a while. Please try the DAQ Assistant trick I mentioned to get the proper functions and order.
Message 16 of 19
(1,867 Views)
Hi Tesla,
In the Measurement and Automation Studio, you can click in the task you created and in the configuration tab. Then you can set the custom scale for each channel.
William Fernandez
Message 17 of 19
(1,841 Views)
There is no such thing as Measurement and Automation Studio. There is however Measurement and Automation Explorer. The op had a problem with the ranges of scales that had been created so your answer would appear off-topic.
Message 18 of 19
(1,837 Views)
There are some clear errors in your code.
If you look at the probes, then probe 45 to 48 has not been executed.
All these probes are in the for loop. That means that you for loop has not run a single time.
As the Task tunnel coming in and the Task tunnel going out of the for loop is a normal tunnel, if the for loop does not run, the value on the Task out of the for loop will be a default value, namely an empty undefined task.
So what can make your for loop not to run?
You have 3 auto-indexed input to the for loop, if at least one of them is an empty array, the for loop will not run.
To prevent the loose of your Task if the for loop is not running, change the Task tunnels to use Shift Register. That will maintain the task value, even if the loop doesn't run.
Message 19 of 19
(1,824 Views)
