DAQmx DO Write Output Buffer before Start Task
I want to write the output buffer before starting the daqmx DO task.
Can I do it somehow similar to the snippet?
Or should I Configure Software Trigger, Start,Write, Fire SW Trigger?
CLA
(1,332 Views)
Accepted by Quiztus2
But you are creating an analog input task from your snippet.
If you are using a sample clock-timed digital output task, yes you should write some data before starting the task. You can refer to the shipping examples.
(1,295 Views)
