DAQmx Documentation Bug (Pascals value)
The Ring Constant value for Pascals is documented as 15881 - it is actually 10081.
Example:
DAQmx Create Virtual Channel.vi, AI Pressure Bridge (Table Scale) instance
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,587 Views)
Nice catch.
(3,544 Views)
Thanks for pointing that out. I'll make a note of it so we can correct that.
Eden K
(3,516 Views)
