Set the front panel size without top and left parameters
Is there a way to set the front panel size, i.e., change only the area (width & height) without touching the top and left parameters?
Front panel area prperty is read only.
Ajay MV
(3,448 Views)
Hi Ajay,
why do you ask when your first snippet already shows the answer?
(3,433 Views)
Asked in a slightly different way here: https://decibel.ni.com/content/docs/DOC-13727#comment-47292
GCentral
(3,412 Views)
Hi GerdW,
I was wondering why that simple straight forward property is not available or am I unaware of it.  Everytime when I do it (I had done several times in past), I wanted to do this math calculation to achieve it.
Ajay.
Ajay MV
(3,354 Views)
