DAQmx Logging on RT works in interactive mode but not headless
I created a little program to run a cRIO 9047 headless. Press the user1 button, acquisition and logging start on a NI9203 module. I am using DAQmx to configure the acquisition and logging. The DAQmx Configure Logging.vi seems pretty basic, and I've checked to make sure that my file path is correct with a little "probe.vi" that writes a txt file to the crio with the file path (or any other info) i wire to it.
When I run the application interactively by running my startup VI from the project window the tdms file is created in the expected directory (/home/lvuser/natinst/bin/Logged Files/<filename>) and the logging seems to work fine. When I build the application and set as startup and restart, i get the same file paths in my probes as i did running interactively but no tdms file is created.
The probe vi write the path to a txt
I tried concatenating the file extension on, even though when running interactively it wasn't necessary.
Tried changing my directory to the application base path from the location i have in an ini file.
Tried changing the name to just a single word instead of "09302024 0915 AM.tdms" format.
Not sure what i am doing wrong here, not reporting any errors and the actual acquisition seems to be working (using some error reporting).
I could just create TDMS files manually or write the acquisition to a txt file, but was trying to do this the easy way with the DAQmx logging.
DAQmx 21.8 on LV2020SP1
(737 Views)
Accepted by TheWolfmansBrother
Is the application running at all when compiled? Does it produce an error?
There used to be a bug in DAQmx that broke DAQmx logging on RT, though that was fixed in 21.8: https://www.ni.com/en/support/documentation/bugs/22/ni-daqmx-21-8-bug-fixes.htm
Maybe you could double check the DAQmx version on the cRIO?
(725 Views)
I added a VI to help show what I've got going.
I experience the same issues when running this as a startup VI as I do my real project.
process:
I added it to target open the VI and click run arrow, it loads it to the cRIO, i can se the front panel and the acquisition occur (running interactively). I can then go into the cRIO files and find the tdms file.
If i build an RT application and set this file as startup, no tdms file is created in the directory. I get no errors, and the LED i have setup to flash on the cRIO flashes when there is no error and acquisition is running.
(720 Views)
Yup, so despite having DAQmx 21.8 installed on my machine, I recently replicated and deployed an older image to this cRIO and it is running DAQmx 20.1. I will go ahead and update the software, thanks.
(717 Views)
