DAQmx Logging on cRIO 9042: Error -201310
Hi everyone,
I would like to use DAQmx logging on a cRIO 9042. Reading waveforms and logging those to TDMS "by hand" works fine. According to this page DAQmx logging should also be possible: Log TDMS Measurements in a Real-Time Application. Unfortunately, I get this error:
Error -201310 occurred at DAQmx Start Task.vi:7220001
Possible reason(s):
TDMS support is not installed or is too old. Use an NI-DAQmx runtime that includes TDMS support, or install a supported version of TDMS from a stand-alone installer.
I'm pretty certain the driver is not too old. I'm using LabVIEW 2020 and the cRIO has these versions installed (excerpt):
CompactRIO Support 21.0.0.49153-0+f1
LabVIEW Real-Time 20.0.1.49159-0+f7
Linux RT System Image 21.0
NI-DAQmx 21.0.0.49316-0+f164
Any ideas?
(3,047 Views)
Hi cordm,
@cordm wrote:
Possible reason(s):
Any ideas?
Is there a separate "TDMS support" package to be installed?
(3,013 Views)
Did you find an answer to this? I encountered the same thing
(2,490 Views)
I did not find a cause for this. In the end, I installed a different system image version and that was the end of it. It might have been a mismatch between LabVIEW versions or something went wrong in the original installation. I used LabVIEW 2020 for development.
The system is gone now, but the last installed image was Linux RT System Image 20.7.0
(2,459 Views)
Accepted by topic author cordm
Found, It is a bug #1839526 in DAQmx versions <21.8.
https://www.ni.com/en/support/documentation/bugs/22/ni-daqmx-21-8-bug-fixes.html
(2,372 Views)
