DAQmx NOT appearing, only DAQmx-base appearing
I'm trying to use the DAQ-Assistant feature of DAQmx to aid use of my ni usb 6008 with Windows 7 x86.
However when I go to the measurement I/O panel of the block diagram only DAQmx-base appears which does not have the DAQ assistant block avaliable.
I've tried installing all the software/plugins recomended in other threads, but the DAQ-mx pannel still doesn't appear. Here is a list of all the software installed:
and the drivers folder:
Thanks in advanced for any help,
Sam.
(2,685 Views)
It looks like you did not get the ADE support component installed (your MAX config shows 9.0.2 and I expect 9.2.2).  Try unintalling DAQmx and get a clean copy from HERE before re-installing.  It may be an issue with the Download
(2,665 Views)
