DAQmx Reset Device hangs
I have PXI-8110 controller with 10 PXI cards in them. When I try to reset these cards using "DAQMx Reset Device.vi", code hangs.  There is no way to recover from this but to cycle power on the PXI controller.
Ofcourse, this happens rarely.
I'm using LabVIEW 2009, MAX 4.6.1f0
(3,029 Views)
Hi Appu,
Do you receive any error message?  Are you handling the errors with a Simple or General Error Handler?  Can you manually reset the devices in MAX?
Best,
Adam
Academic Product Manager
National Intruments
(3,014 Views)
