Motherboard recommendation for RT?
Can anyone recommend a good motherboard that is compatible with RT? I'm thinking dual/quad-core, parallel ATA, compatible ethernet chip, >=3 PCI slots. A specific model someone has tried that works would be ideal.
Thanks!
Ben
Message 1 of 21
(5,658 Views)
I am looking into this my self. I found some tips in the links below
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PhCAI&l=en-US
Requirements for Desktop PCs as LabVIEW Real-Time Targets.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LwrSAE&l=en-US
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 2 of 21
(5,648 Views)
We have been having a heck of a time getting a PC to work as a real-time target. NI does *not* make this easy. We have assembled the following system, which by all the guidelines should work. It did initially, but now the USB test program hangs at "Transferring to user control". Anyone have any ideas?
ASUS P5GC-VM Motherboard
Socket 775 Intel Core 2 Duo, E8400, 3GHz
2GB DDR2-800 Memory (Matched Pair)
Western Digital IDE 160GB HDD, 7200
Intel Pro 100/S Network Adapter
Ben
Message 3 of 21
(5,595 Views)
Please make sure that the mother board has PCI BIOS support...
Claire Reid
Message 4 of 21
(5,546 Views)
Has anyone solved the problem or maybe someone can advise pc configuration suitable for using as a rt target? Motherboard, processor..
Message 5 of 21
(5,318 Views)
Hello przemmo,
After reviewing this forum, there are several links about that go into some detail about how to choose your motherboard, processor, etc like Requirements for Desktop PCs as LabVIEW Real-Time Targets. Have you looked into this information?
JimS
Jim St
RF Product Support Engineer
Message 6 of 21
(5,272 Views)
Claire R wrote:
Please make sure that the mother board has PCI BIOS support... See this KB PCI BIOS Support for a Motherboard on a RT PC
Why? The requirements document states that PCI BIOS Support is only required for LV 8.2.1 or earlier.
I tried to use 2 mainboards for LV 8.5 RT about half a year ago. Both didn't work, even though the system fulfilled all the requirements.
I think the only way is to choose a system that meets the requirements and then test it. This is a pain...
There's several threads about this in this forum, e.g. this one.
Message Edited by dan_u on 05-11-2010 08:43 AM
Message 7 of 21
(5,252 Views)
Hello Dan,
In order to simplify matters with this, I have looked into seeing what we have found that works and I have listed the specifications below. This isn't considered to be a supported option but it might simplify matters when choosing a system.
Out-of-the-Box Solution:
Dell Precision T3500 Workstation
2.4 GHz Intel Core2 Quad CPU
2.0 GB (Dell standard) RAM
List to Buy Single components:
Motherboards:
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
Intel® Desktop Board DH55HC
CPU:
Intel® Core™ i7-860 processor
Intel® Core™ i3-530 processor
Network Interface Cards:
Intel PRO/1000 GT
Intel PRO/1000 PT
I hope this information helps with building your RT PC.
JimS
Message Edited by Jim_S on 05-11-2010 04:26 PM
Jim St
Message 8 of 21
(5,218 Views)
I wonder wether the Intel pro/100s will work with the DH55HC motherboard. I am going to buy The i3 and DH55HC. Are ther any special requirements according ram and hard drive?
Message Edited by przemmo on 05-12-2010 02:09 PM
Message 9 of 21
(5,199 Views)
Hello przemmo,
As for these requirements, I would consult the Requirements for Desktop PCs as LabVIEW Real-Time Targets and it discusses in detail about how much RAM is supported by Real Time OS and which type of hard drive is supported as well. I hope this information helps you.
JimS.
Jim St
Message 10 of 21
(5,179 Views)
