DAQmx Switch LED Sequencing/Timing
Hello all,
I am new to Labview (started today) and I have to control 3 switches and watch 3 inputs (LEDs).  I am a microcontroller/C guy, so all this is confusing to me.
I was able to get Labview talking to the NI box so I can control the switches (outputs) and read the LEDs (inputs).  After that I am totally lost.
All I want to do is loop (indefinitely) and:
1. Turn on Valid (switch 1), start a timer and wait for OK (LED 1) to turn on.  Write the timer value to a file with a date/time stamp.
2. Turn on Request (switch 2), start a timer and wait for GRT (LED 2) to turn on.  Write the timer value to a file with a date/time stamp.
3. Turn on POD Placed (switch 3), start a timer and wait for Placed (LED 3) to turn on.  Write the timer value to a file with a date/time stamp.
4. Turn all switches off and restart loop.
If someone can show me how I can put the switch inside a loop, turn it on, and wait for the LED with a timer, that would help so much.
Thanks!
Message Edited by pzoom on 10-28-2008 11:05 AM
(4,045 Views)
Hi pzoom,
Welcome to LabVIEW! I'm going to give you a few pointers towards information that maybe useful to you. Have you looked at the example finder? You can find this by going "Help->Find Examples..." from a blank VI and searching for topics from there. There are a number of different ways that you could calculate the time. You could compare the system clock (Tick count) before and after your code; this could be done using a flat sequence (attached image). Or you could use the "elapsed Time" Express VI (Located at  "Expres-> Exec Control"). There are a number of different timing solutions available from the Timing palette "Programming->Timing". Specifically there is the  Ge Date/Time in seconds Vi which would probably be of use.
If you need further help please let me know,
Andrew McLennan
(4,030 Views)
Thanks Andrew for the reply.  Could you tell me how I can set the switch within the loop?  In C, I would set SW1=1 - how do I do that in LV?  I can seem to find examples using the DAQmx for simple I/O.
(4,019 Views)
Hi pzoom,
If you wish to reset something, I would suggest you use local variables. I've attached an example VI which will turn an LED on for one second and then reset the switch. Please have a look at this code to see the operation. In order to create local variables, right click on any control or indicator you have, and go to  "Create->Local Variable". You can change local variables to either Read or write by right right-clicking on the local variable and pressing either "change to read" or "change to write".
Andrew McLennan
(3,998 Views)
Hi pzoom,
Can you please tell us the model number of the NI hardware that you are using?
Best wishes,
Wallace F.
(3,985 Views)
