10-29-2008 09:46 AM
I would like to know if there is a way I can add a VI into a .llb library? Ortherwise if I need to rebuild the llb, please tell me what is the good way to make an llb with an already llb and some external VI which I want to add to the new llb.
Thang
Solved! Go to Solution.
10-29-2008 09:55 AM
Hi Thang,
you can use the "llb Manager" or you save it directly into the llb. You can select the llb in the same way as a folder.
Hope it helps.
Mike
10-29-2008 10:22 AM
Mike,
Could you please tell more detail?
I have a seperate VI and a llb. Now I can use Project Explorer to add the file into the llb but the file still stay independently. It is still not saved as a VI inside the library. When I open the llb Manager, there is no function to add file.
10-29-2008 10:40 AM - edited 10-29-2008 10:41 AM
Hi!
Just use Drag and Drop in LLB Manager. Its working. Useful if file already exists:
Or File->Save As... then select LLB and save directly in LLB as Mike mentioned. This way useful for new files.
Andrey.
10-29-2008 11:04 AM
10-29-2008
11:16 AM
- last edited on
04-28-2025
02:50 PM
by
Content Cleaner
Agree with Dennis. I've got corrupted library too (but it was LV 6.0). And for SCC they are not very good. Take a look on libraries (*.lvlib) - probably this way is better for you.
Andrey.
