DAQmx Switch VI have red X
I opened my old vi (2012/2013) in Labview 2015, all the DAQmx Switch palettes have a big Red X on the VI's.
as shown here:
Is this something that has changed in Labview 2015?
Is there a way to migrate the old files to the latest version?
(4,491 Views)
Is there a specific popup if you try to open the VIs?
A solution may be to replace them with the appropriate VIs from your palette.
Cheers
(4,477 Views)
If I double click on any of those VI, the sub VI opens up and I do not see any errors within those subVI from what I can tell.
Here is a screen shot of the block diagram of  "DAQmx Switch Set Topology and Reset.vi"
I don't have the physical hardware to check if the VI is still functional.
(4,468 Views)
Accepted by vikasg
If the VI opens and doesn't have a broken arrow, I think it might run okay... It may just be a discontinued version and the X is just telling you to replace it if you can.
Cheers
(4,462 Views)
