DAQmx Task in build
I have an USB-6001 and I am not able to make it working properly.  I lost the Task in the build.
My project with the task:
In the Development Mode I have access to the task and I measure the correct values.
In the build, I don't have access to the task.
What I am doing wrong?
Jean-Marc
(4,055 Views)
Did you include DAQmx run-time engine?
Or better yet, install DAQmx with development support?  Does Measurement and Automation Explorer exist on the PC you are running this exe on?
(4,037 Views)
Actually, I work only on my development PC.  It is the reason that this drive me crazy...
In the data folder of the build I have the Ni-DAQmx.txt file.
Jean-Marc
(4,028 Views)
You need to make sure MAX is installed on the PC where you are having problems.  It looks like you don't have any tasks created there.
(4,000 Views)
It is the same PC:  I run the VI in the development mode and everything is fine.  I built the executable on the same PC and I run it: it seems that the Task disapears.
Jean-Marc
(3,993 Views)
I'm sorry.  I misinterpreted what you said.
So does the task exist in MAX?  Or was the task only in the project itself?
(3,986 Views)
I just created a new Application with the same properties than "Cyclone de laboratoire R&D" and now it's working...
Jean-Marc
(3,985 Views)
