DAQmx custom scale: how do you set MIN and MAX values?
It is in mA only, 4-20 mA. But, there is no option select "mA" from the menu so, 0.004 to 0.02 Amp.
Still no luck after running the graph, I am not getting anything on the graph!
The connections are correct as it is running fine in DAQ Express. Not sure why I am not seeing any data in NI max w/ no error!
Message 11 of 15
(1,136 Views)
Attach your actual VI.
Another thing you can do if you keep struggling with built-in scales is to just read the values as Amps, or milliamps, and proceed to do your own mathematical conversion in LabVIEW to degC.
Message 12 of 15
(1,131 Views)
Hi RavensFan,
I do not have any VI as of now. Not familiar with LabVIEW so I am trying to avoid designing it in LabVIEW. I thought, I would just scale this NI max and if all works then learn/design this in LabVIEW. I am reading an actual mA value in DAQ Express, please see attached,
Message 13 of 15
(1,129 Views)
I'm not familiar with DAQ Express.  I didn't even realize that was a product.  I thought you were talking about the DAQ Assistant Express VI in LabVIEW.
I see there is a DAQExpress forum.  You might want to post over there instead of this thread.
Message 14 of 15
(1,119 Views)
Will do.
BTW, I found a solution in DAQ Express itself. I added a scalar block to scale 4-20mA to 0-150 deg C. Please see attached.
Appreciate all your support on this.!! 🙂
Message 15 of 15
(1,085 Views)
