VISA resource connected
I would like to check if a VISA ressource is already in use.
This seems to be indicated by this symbol in the VISA resource name control:
Where can I find documentation about the meaning of this symbol?
Is it possible to read the status of the connection programmatically in code?
Thank you!
Thomas
(3,120 Views)
Accepted by topic author THBU
Hi Thomas,
You can read open VISA sessions using this code:
Vilius
(2,672 Views)
Thank you, Vilius
If someone else should look for this VI, it is located in Program Files (x86)\National Instruments\LabVIEW 2019\vi.lib\Utility\visa.llb
(2,663 Views)
