Seting the RepCapIdentifier of an IVI driver
Hello
I have created a LabVIEW driver using the LabWindows/CVI FP importer.
The IVI-C prototype of the attribute setter for string attributes is:
ViStatus AqSsoct_SetAttributeViString(
	ViSession Vi,
	ViConstString RepCapIdentifier,
	ViAttr AttributeID,
	ViConstString AttributeValue
I have found how to access the property in LabVIEW using the Property Node but how should I set the RepCapIdentifier?
Regards
Yannick Willener
(2,598 Views)
Have you got a LabVIEW example you could post on here to view your code an to see how you are using the Property Node?
S.N
(2,567 Views)
Hello Shezan,
Sorry for the late answer. I'm just back on this project.
I have attached an example. I can't figure out how to connect the rep cap identifier.
Thanks for you help.
(2,443 Views)
