DAQmx error 6704
Hi, we've realized a task that collects data from file and set the output in analog way [4-20 mA] with 3 device 6704 PCI. The OS is XP SP3, the platform is LV 7.1 and the DAQmx version is 8.9. Very often the program crashes with message depicted in the attach. When it appens the PC do not respond to any command given via TCP/IP so it is not more available the remote control. It seems that the DAQ start task.vi sometime can't find the device even if the OS can manage correctly the 3 PCI card. Did anyone met this kind of trouble and found a workaround? Thanks in advance Chyrusys
(2,625 Views)
I found some information in the following forums that can be useful. Can you please take a look?
http://forums.ni.com/t5/LabVIEW/corrupted-LabVIEW-s-memory/m-p/558031/highlight/true#M262099
If I understood well from your desktop, you are Italian. Can you please take a look at this forum also?
http://forums.ni.com/t5/Forum-Italiano-sui-Prodotti-NI/problema-al-node-0X19E4/m-p/383384/highlight/...
Can you let me know if you have good results after you tried the above? Thanx!
Antonios
(2,598 Views)
