Unable to set tabbing order for a typedef
Attached is a .CTL file that is for a typedef in my project. I'd like to set the tabbing order. I'm using the "Array to Cluster" VI (is it a VI?) to fill it with data, however because the controls are not in the correct order, the data is no being put in the right place. When I edit my CTL, Edit|Set Tabbing Order is greyed out. Why is this and how do I fix it?
See my attached file.
(3,034 Views)
Accepted by topic author Xooch
Never mind - I figured it out. Right click on the cluster containing my controls and select "Reorder controls in cluster..."
(3,033 Views)
