DAQmx not correct number of samples read
This morning I got access to a computer with the NI-6353 card. When running the code on this card, the proper amount of samples is acquired (1000, 2000, 3000) as it should be.
I guess the glitch is only for simulated DAQmx cards.
Message 11 of 13
(497 Views)
Good to hear that.Did you try your original code or did you use some of the code we discussed for trying things out?
Norbert
Norbert
Expert: Geometry
Message 12 of 13
(492 Views)
Both. It all works well on the real hardware as it should. It's only for the simulated devices it doesn't work as discussed.
Message 13 of 13
(489 Views)
