DAQmx not showing terminals
DAQmx is not showing terminals....I have checked ActiveX box, applied UAC changes and double clicked on DAQ assistant but still missing the terminals....Please help me...
Message 1 of 13
(4,962 Views)
Hi Assad,
Which "ActiveX box" is checked?
Why do you need to "apply UAC changes"?
What happens after "double-clicking the DAQ Assistent"?
More importantly:
Which LabVIEW version do you use?
Which DAQmx version did you install?
Can you show a screenshot of the "Software" subtree in MAX?
Which devices does MAX show? Which devices are connected (or built in) to your computer?
Message 2 of 13
(4,930 Views)
I m using Labview 2013, DAQmx 16.0.1.
Reason why m performed that three actions is attached...
I m new user... so donot have much knowledge of labview....
Message 3 of 13
(4,925 Views)
Hi Assad,
what have you configured your DAQAssistent to?
What about the MAX screenshots?
Message 4 of 13
(4,919 Views)
just dragged DAQ assistant to block diagram...
Message 5 of 13
(4,900 Views)
Message 6 of 13
(4,895 Views)
Hi Assad,
How did you configure the DAQ Assistent?
Message 7 of 13
(4,879 Views)
what do you mean by configuration when nothing is there without a DAQ assistant box??
Message 8 of 13
(4,874 Views)
Double-click on the DAQ Assistant.  It should open up a configuration window.
Message 9 of 13
(4,869 Views)
Accepted by RavensFan
I am using Labview 2013, DAQmx 16.0.1.
That's what you say.
But looking at your MAX report, it syas you have DAQmx 17 installed.  (Kind of unclear because the 17 just fit onto the pane before getting cut off.)
LabVIEW 13 isn't supported by DAQmx 17.
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Message 10 of 13
(4,832 Views)
