DAQmx port
How can I set the DAQmx Ceate chanel block in my attached code to a constant so that it always goes to Device 2 port0?  I don't want the pull down menu on my front end.
(2,991 Views)
Right click on it and select "Change to Constant".
(2,987 Views)
Here are a few quick and easy ways:
1)  You can right click the control and go to ADVANCED -- ENABLED STATE -- DISABLED(or DISABLED & GRAY).  This way you can still edit the selection during development but during runtime it will not be able to be changed.
2)  If you do not need a front panel display you can replace the control with a constant.  This does take away the ability of using this VI as a SubVI and sending it different channels.
3)  You can right click the control and go to VISIBLE ITEMS -- MENU BUTTON.  This will take away the pull down menu button but can still be changed and/or selected during runtime if it is not disabled.
Hope this helps
Steve
(2,983 Views)
