NI hypertrend resizing on a browser
Hi
I am publishing NI hypertrend on a browser using the web-publishing tool. The problem is when I open the browser on a different machine with a different resolution everything gets resized except for the NI Hypertrend. When I created the application I set all the options on the window size property. When I open the browser on the machine I created the application everything looks fine. Can anyone help? By the way I am using LabVIEW DCS 7.1.
Sala
(2,552 Views)
The KnowledgeBase entitled Using NI Hypertrend and Alarm & Event Display with Remote Panel says that,
" This is a known behavior you are seeing. In general in LabVIEW, you cannot view ActiveX controls or objects when using Remote Panel. ActiveX controls embedded on a front panel do not display on a remote client because they draw and operate almost completely independently of LabVIEW. The NI Hypertrend object and the Alarm & Event Display are ActiveX based. Thus they are not supported in Remote Panel. Try using non-ActiveX objects such as the Historical Trend indicator or the Alarm Summary Display Listbox instead."
Here is a related discussion forum that reflects how this object will not work with remote panels...
Browser can't load HyperTrend in a Remote Panel Application
Sorry to be the bearer of bad news!  You might have to use the Historical Trend indicator to meet your application needs.
(2,542 Views)
