DAQmx: read recent sample while logging to tdms file
Hi!
I want to use the DAQmx logging function to write my measurement data to a tdms file. The measurements are taken at a high sampling frequency (50kHz to 10MHz). Meanwhile I need a few samples in my automatisation software for controlling purpose. Therefore a sampling rate of 10Hz is totally sufficient.
Until now I dindn't manage to configure the tdms logging and only read one sample per channel by usind DAQmx Read every 100ms. Also the DAQmx Read setting "RelativeTo: MostRecentSample" seems not to be available while logging data.
Does anyone have another approach to read one sample per 100ms while logging data?
Best Regards,
Dennis
(3,178 Views)
Hi Kokoloris,
You can use the TDMS Write function after you acquired the data with DAQmx functions as shown in the attached example.
But note that this is a software-timed example and if you want to be more precise you can turn it into a hardware-timed VI by wiring a source to the DAQmx Timing VI.
Tamara Moullet
(3,156 Views)
I am using a realtime system and I want to take advantage of the direct logging of data from the card's buffer to the harddisc:
http://zone.ni.com/reference/en-XX/help/370466V-01/mxcncpts/datalogging/
Therefore I don't want to use DAQmx read to acquire all samples, because I'm afraid it is too much data...
(3,151 Views)
Ok, in this case, the best solution would be as shown in the example "Voltage Continuous Input.vi" that you can find under
Help>Find Examples>Hardware Input and Output>DAQmx>Analog Input
or like in the attached example if you want to split data between several files.
Tamara Moullet
(3,142 Views)
