08-06-2013 01:51 AM
Hi!
I want to use the DAQmx logging function to write my measurement data to a tdms file. The measurements are taken at a high sampling frequency (50kHz to 10MHz). Meanwhile I need a few samples in my automatisation software for controlling purpose. Therefore a sampling rate of 10Hz is totally sufficient.
Until now I dindn't manage to configure the tdms logging and only read one sample per channel by usind DAQmx Read every 100ms. Also the DAQmx Read setting "RelativeTo: MostRecentSample" seems not to be available while logging data.
Does anyone have another approach to read one sample per 100ms while logging data?
Best Regards,
Dennis
08-06-2013 07:27 AM
Hi Kokoloris,
You can use the TDMS Write function after you acquired the data with DAQmx functions as shown in the attached example.
But note that this is a software-timed example and if you want to be more precise you can turn it into a hardware-timed VI by wiring a source to the DAQmx Timing VI.
08-06-2013
07:43 AM
- last edited on
07-08-2026
10:04 AM
by
Content Cleaner
I am using a realtime system and I want to take advantage of the direct logging of data from the card's buffer to the harddisc:
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/datalogging.html
Therefore I don't want to use DAQmx read to acquire all samples, because I'm afraid it is too much data...
08-06-2013 08:51 AM - edited 08-06-2013 08:53 AM
Ok, in this case, the best solution would be as shown in the example "Voltage Continuous Input.vi" that you can find under
Help>Find Examples>Hardware Input and Output>DAQmx>Analog Input
or like in the attached example if you want to split data between several files.
