DAQmx reads (or writes) in parallel vs. series
Is there any efficiency difference between putting DAQmx reads (or writes) in parallel vs. series?
(3,226 Views)
Sorry to to be vague, but the answer really depends on what you are trying to do. If you are trying to do reads from different channels, you know you can use the ':' and ',' operator while creating the task and then use one read or write VI.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,203 Views)
Accepted by Mark Shepard
Well said.  In addition, using serial would create data flow dependencies, so the reads could not happen at the ame time, where parallel would remove the dependencies.
Adam
Academic Product Manager
National Intruments
(3,167 Views)
Consider error handling. If one task fails to initialize, are the others still 'safe' to run?
I use parallel DAQ a lot, but I sync their 'parallelism' on the hardware layer (PXI or RTSI). Code (at the hardware abstraction layer) is about catching the errors correctly.
Felix
(3,151 Views)
Thank you all very much
(3,145 Views)
