DAQmx vis missing
I have installed DAQmx9.9.0 and cannot find the DAQmx vis neither in Labview or in instr.lib
In Max,
Help!
(3,656 Views)
What version of LabVIEW are you using ?
That version only support:
  NI LabVIEW 2010, 2011, 2012, and 2013
(3,652 Views)
What version of LabVIEW?  Did you install DAQmx AFTER installing LabVIEW?
(3,651 Views)
I installed lbv2012
I installed Daqmx after lbv2012
(3,643 Views)
Accepted by topic author Miles3
The DAQmx files should be in the vi.lib\DAQmx folder under your LabVIEW version.
If they are not, try to install DAQmx one more time, and make sure you have checked the support for LabVIEW 2012 in the install configuration.
(3,639 Views)
