How to convert the date and time difference from the current date and a selected date into seconds?
Im making a clock with an alarm, and i want to be able to set the date that the alarm will go off, however to do this i need to be able to convert the difference between the current date and the target date into seconds in order to be able to use it in the elapsed time vi. Does anyone know how to do this? Or is there a better way to achieve this?
(3,923 Views)
Have you tried the subtract function? You are using timestamps, aren't you?
(3,921 Views)
Why do you need to use the Elsapsed Time function?  Just compare the current date/time to the alarm date/time.  Doing it this way will also allow you to save the alarm date/time to a file and you can shut down your program and come back to it.
GCentral
(3,916 Views)
How to i get a time stamp to automajically set itself to always be the current time?
(3,912 Views)
Accepted by topic author nickom
Hi nick,
you get a timestamp from GetTimeInSeconds
(3,908 Views)
Well i want it to have like the autoreset and stuff, that way i might try afterwards though, still getting used to it:)
(3,907 Views)
I'm not sure if this is what you're looking for, but have you tried the "Get Date/Time In Seconds" VI?  I don't know how you're updating your clock, or at what frequency you require it to be updated, but if the update frequency you need isn't too high (say, <500 Hz) I don't see why putting the "Get Date/Time In Seconds" VI inside your update loop wouldn't work.
(3,899 Views)
