DAQmx with touch panel
I am trying to use DAQmx with the touch panel module, but am having some issues. I find that when editing a touch panel VI, the DAQmx options disappear from the functions palette. If I bring them in from elsewhere, the VI will not run properly. Is this normal?!
Also, does anyone have any tips for how to install the driver for DAQmx base onto an NI TPC-2106T?
mstudio
(2,788 Views)
Hi mstudio,
you need to use DAQmx Base 3.1 for use with the TPC-2106T. You can download it from:
http://joule.ni.com/nidu/cds/view/p/id/971/lang/en
Also you need to use the LabVIEW 8.5.1 Touch Panel Module which you may have already received if you have an active service contract with National Instruments.
Let us know how you get on.
KostasB
NI UK Applications Engineer
(2,769 Views)
Thanks - yes that was what was needed!
Regards mstudio
(2,747 Views)
