how to chang cluster of 2 elements( 2 measurement data 1 D array of (double[64-bit])) to dynamic data?
I need to do FFT transform, the input data type for FFT transform is dynamic data type, but the waveform from XY graph which time value is set by X axis and amplitude is bst by Y axis.
thank you for all your help
jing
(3,305 Views)
Hi jing,
can you please upload a vi with the information you currently have?
Mike
(3,300 Views)
thank you very much Mike!!
(3,284 Views)
maybe this one is much clear for my problem. very appreciate for your help!
(3,283 Views)
Hi jing,
you have to create a waveform. I changed your example. if your time values do not have the same dt you have to interpolate it first.
Mike
(3,277 Views)
ah!!!!!thank you so much for your help!!!my problem is solved!
I am a new to labview, this problem bothered so many days, so much appreciate for  your help!!!thank you again!!!
if you like I want to be friend with you, my name is Jing WEN, I am chinese, now I am studying in munich Germany.
my MSN:weixuan0713@hotmail.com
Thank your so much!
JIng
(3,270 Views)
