DATATranslation LV-LINK
I want to write a small program for using DATATranslation LV-link to get  analog input singals from two channels at the same time.
Then I want to get the ratio of the singals from the two channels. I want to continuosuly acquire the data and display them and save the relevant singals from the two channels and the relevant ratio in txt format file.
I tried the LV-link program, it seems the DATX only get the signal from only channel. What is the reason? Could you help me out?
(2,874 Views)
Have you asked Data Translation? You may be using LabVIEW but it's their hardware and software. You may get lucky here but I'd recomend going straight to DT first.
(2,869 Views)
Can send the link of datasheet of hardware that u r using?
(2,861 Views)
HI,
Here attached is the program, Could you help me with this? Thanks
(2,847 Views)
