how i can controll one joint Arm by EMG signal
        i am working on EMG signal. I want to controll one joint robotic arm by EMG signal in Robotic toolkit
        Please Guide me how i can controll the robotic arm by EMG signal generated by bicape musle.
       looking for your kind help.
     M Abbas
(2,260 Views)
Mujahid:
You may have more results to your question if you phrase it more specificly. What you're describing is a rather complicated system, and it's likely no one here has performed precisely what you're attempting to do.
Generally, if you ask a specific question about an issue or problem you're having with your program, you're more likely to get a response.  Robot Happy
Caleb Harris
National Instruments | http://www.ni.com/support
(2,231 Views)
