DAXmx driver not installed
I am a senior ME at Grove City College.
I am running a USB-6501 digital I/O device.
I am running Labview 2009.
I am trying to build an EXE application.  I have downloaded the Labview runtime engine on an independent computer.  When I try and run my compiled code I get a NIDAQmx error.  I believe I need to install the drivers for this device.
Can I install the DAQmx drivers from the NI website and then run my compiled code?  Or do I have to use the application builder and incorporate the drivers into my compiled code?
Thank You
(2,886 Views)
You can download and install them from here.  (you could have included DAQmx in your exe installer but any way the driver installs results in the driver being installed
(2,884 Views)
If you are just using a built executable, you can use the NI-DAQmx Core runtime, which will allow the executable to run and is the smallest possible download.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,864 Views)
