DB Tools: SELECT for checking if record exists?
I am using the Database Connectivity Toolset.
Our IT guys adviced me that I should use the SELECT clause to check if a record exists in a table.
When I send from labview through a UDL file:
SELECT id
FROM [ProdTestData].[dbo].[TestResults]
WHERE MONumber='C00322'
I do not get anything back. See attached.
When the IT guys do the same from their API, they get back a number.
Do I need to add a FETCH or something else to my VI?
Scientia est potentia!
(2,780 Views)
Accepted by topic author magyar
Try adding DB Tools Fetch Recordset Data.vi between your query VI and the Free VI.
(2,775 Views)
That worked.
When i tried this previously, I did not click on "ShowType" in the variant indicator. So I didn't see anything in  the variant indicator if the record did not exist.
Thank you.
(2,770 Views)
