07-12-2020 12:53 PM
Hello Team,
I am dealing with MSSQL query which takes not less than 60 seconds to execute. But i am always getting LabVIEW popup which says Query Timeout expired. So I learned that there is a default timeout of 30 sec for DB Tools execute query.vi and can be changed by using DB Tools Set Properties.VI. Can anybody explain me how to use this VI? I tried to set timeout as given in the screenshot but getting property value is invalid error.
Thank you in advance.
Code Snippet
Invalid property error
Topic which mentions about DB Tools Set Properties.VI
10-14-2020 01:48 PM
It's because you are passing no args. Try this:
