How to Ping an IP Address from LabVIEW NXG?
I use the source code from How to Ping an IP Address from LabVIEW?  How do I do this from LabVIEW NXG?
I tried the conversion utility from LabVIEW to LabVIEW NXG, and got code with a broken run that has placeholders for all the .NET calls to Windows OS ping.
I tried Select Assembly from DotNetInterface.dni, and find that the only choice when searching for ping does not show any entry points (see attached).
(1,495 Views)
The easiest way - in both NXG and Classic - is to use system exec to execute the ping command.  You can capture stdout and parse for info.
LabVIEW NXG 5.0 Manual System Exec (G Dataflow)
Bill
CLD
(Mid-Level minion.)
(1,477 Views)
