DB tools insert data too slow
I have an application in Labview and use the mySQL database, a communication made with the database of DB tools, but when I enter data in the program it takes about two seconds. My computer has an Intel core I5 processor and 8GB of RAM.
Can someone help me please?
Forgive me for my English, I'm Brazilian.
(3,963 Views)
Without any more information it's impossible to answer. Post your .vi so we can see if there's any obvious mistakes.
Qestit Systems
Certified-LabVIEW-Developer
(3,957 Views)
database inserts are normally very quick.  how many records are you trying to insert? how does the time compare with an insert done by another program (this will help determine if the problem is on the server side)?
(3,931 Views)
My application is very complex, so I did a VI to test the communication tool with the database. But even so, execution is delaying. I tested the insert method and the select data, both presenting the same problem.I am inserting a constant cluster for testing purposes only.
(3,925 Views)
first thing... your timed loop is set to only run once per second (dt =1000), so you can't actually perform DB inserts any faster than that.  not sure if your full program has the same problem.  Don't use a timed loop, but an event structure set to respond to a button's value change event.
(3,921 Views)
I use the timed loop with one second is why I really want my updates in the bank every second. I even changed the time loop for a normal while loop, but even then the delay continued, it's as if the VIs in the database had an internal delay.
(3,913 Views)
in that case, I highly recommend you perform a similar insert using sql server management studio to see if the problem is external.  in my experience, DB inserts via LabVIEW were normally < 100 ms.
(3,911 Views)
