03-18-2020 03:40 PM
I've been having problems with launching NI MAX. Right after launching MAX, I see the splash window with the description "Initializing...". Shortly after this, another window comes up with the following message
NI MAX has detected an unexpected internal warning. Visit ni.com/info and enter the info code MAXKnownException for more information.
In the details section of the window, I see the following:
The CniDMFuiProvider::Initialize plug-in caused an exception in the CmxExecutionThreadPool::DoWorkNonUI function in the MAX process.
See this file for details:
C:\ProgramData\National Instruments\MAX\Logs\MAX\cfa87bbc-9467-4a1e-8425-a0f989b583d2\c97ebd86-9085-4d7e-8a21-c959fb281b93.dmp
I have restarted computer to see if behavior persists. Also I went into control panel and tried to do a repair on NI MAX.The problem is that when I open the program and right after the error message the program freezes and you can't go to different tabs to check the configuration. There is not a recent change e.g. upgrading the version or unexpected shut down, ...
I have attached a screenshot of the program error.
Any ideas on what my next step should be?
03-18-2020 05:12 PM
Did you actually follow the instructions in the error pop-up? Usually NI has a very good explanation if they say to go there.
03-18-2020 05:52 PM
Thanks for your comment. I tried to find this dmp file but I could not find it:
Could it be a missing file?
I also reset the configuration but it didn't work.
I got nidevmon.exe system error which says try to reinstall. Should I try that?
03-18-2020 06:12 PM
I do have another question. When we want to uninstall the program, should I uninstall all the components?
03-18-2020 06:29 PM
You could try to reset your MAX database in case it's corrupt and causing your issue.
03-18-2020 06:38 PM
I tried that but didn't work. See the error:
03-20-2020 09:35 AM
I have to confess that I'm now paranoid of uninstalling/reinstalling anything NI-related ever since they started using NIPM.
03-20-2020 12:55 PM
Now I have fixed the previous issue, but the it can not detect the device.
04-09-2020 12:23 PM
Hi. Could you tell me how you solve this issue ? I've got the same, and event after repaire in NIPM, it's still there
