DC Motor Speed Control Simulation
Hi Everyone,
I am very new to LabVIEW and hoping to get some help on troubleshooting my DC Motor Speed Control Simulation, I have created a simulation that can run, however, both my maximum speed listed in the attached tables cannot be obtained and my PID is far from working any help would be very much appreciated. I'm hoping it has just been a design issue within my VI which I have attached, the LabVIEW version I am using is LabVIEW 2019 SP1 32- bit and all the motor data required can be viewed within the table attached. Again, thank you for any replies I might receive.
(1,072 Views)
Hi zpaul,
  • The PID output range is limited to [0…10], while the datasheet mentions 15V nominal voltage…
  • How did you define the PID gains? There is a "speed constant" given in the datasheet and I would expect a Kc of 0.02 (as reciprocal of 491 rpm/V)…
  • Please define "PID is far from working"…
(1,057 Views)
Hi thank you for your reply, when using PID the speed violently oscillates from 0 to maximum resulting in the graph to draw a complete solid wall of data. I am hoping that changing components that you have listed above may fix this result, however, I also think I have miss developed my transfer function again any help on this aspect would be greatly appreciated can't thank you all enough, cheers.
(1,003 Views)
