DC Motor Speed Control labVIEW FPGA
i have created a Vi to control the speed of two Dc Motor but i am not able to control the speed from labview i.e the amount of current which is applied to the h-Bridge ..the only option i have is to use potentiometer..was asking if anyone can help me how to control the speed of the motors..any help will be highly appreciated.
much regards
(3,261 Views)
Hi meschack103!
At the beginning try to develop your code only for one motor direction.Try to name your UI / block diagram elements in more appropriate way because now it's really confusing. I assume you're trying to achieve a PWM signal generation.
- Add new frame to Flat sequence (at the beginning) and put there Loop Timer.
- Remember that you can always extend I/O Node and control more than one output synchronously.
- Part of your code outside the while loop will not be executed.
Except this rest looks good and you should get PWM as an output.
Regards
(3,215 Views)
