DI-148
TENGO EL SIGUIENTE PROBLEMA.
ESTOU INTENTANDO CONECTAR DOS DI-148 CON MI PC Y LABVIEW, ya consegui capturar la informacion de los ocho canales independientemente ( monitoreo los 8 canales) de un DI-148; pero cuando conecto los dos y repito la rutina se bloquea todo.
ya hice variaciones en el programa, pero siempre hay un error comun en la herramienta  VARIANT TO DATA, que aun no consdigo entender como funciona.
alguien tiene experiencia  conectando mas de 1 DI-148.
gracias
(3,709 Views)
Spanish to English:
I have the following problems.
ESTOU trying to connect TWO DI-148 with my PC and LabVIEW, and got the information capture of the eight independent channels (monitoring the 8 channels) of a DI-148, but when I connect the two and repeat the routine freezes everything.
I did variations on the agenda, but there is always a mistake common tool in the VARIANT to date, which consdigo not even understand how it works.
someone has experience connecting more than 1 DI-148.
thanks
Message Edited by mathan on 09-09-2008 05:58 AM
(3,696 Views)
No damos soporte a las placas DI-148 de DAQCARD, mire los links abajo para informaciones de como las usar con LabVIEW:
http://www.dataq.com/support/techinfo/starterkitextra.htm
http://www.dataq.com/support/upgrades/3rdparty/index.php
Dario Camargo
NI Brazil
#1233583
(3,659 Views)
We do not support the cards DAQCARD DI-148, check the links below for information about how to use them with LabVIEW:
Dario Camargo
NI Brazil
#1233583
(3,658 Views)
