I have activated SVT 6.0 however it does not show installed in the find examples
I have the Sound and Vibration measuremnt suite installed and the Sound assistant works.  However when go to look at the examples in Find examples in Labview 8.6 it shows not installed.
Any ideas
(2,343 Views)
Hello Tim Nrc,
Thanks for your post!
I am sorry to hear that you cannot access your examples for Sound and Vibration. I want to let you know that you can always navigate straight to them using windows explorer.
C:\Program Files\National Instruments\LabVIEW 8.X\examples\Sound and Vibration
I would like to ask if you have multiple versions of LabVIEW installed on the system. If you recently installed LabVIEW 8.6 then the examples would only be installed for the last version. So to get the examples you can simply uninstall and reinstall the Sound and Vibration Measurement suite and add support for LabVIEW 8.6. Let me know if any of this information helps/assist you to getting your SVT example programs.
Cheers!
Corby_B
http://www.ni.com/support
(2,316 Views)
