DLL Expected Exported Functions Not Shown
Hello! I'm trying to call a DLL for writing a special type of files called MDF4 but I do not see the expected exported functions that I need to call when I configure the Call Library Function Node. I managed to register the dll as specified in the documentation and it seems that functions are defined in header but I see only 4 functions in the drop down menu which are not even defined. If I write a name of a function in Function name (like CreateMDF4), parameters are automatically configured just like they are defined in header but I cannot run the VI due to error: Function not found in library.
I also tried to load the dll in a .NET container but could not find it in the list and to import the dll using the wizard but it can see only the 4 functions which could not be wrapped due to missing in header.
Any hints about what else I could try? Thank you!
DLL downloaded from here
LabVIEW 2015 SP1 32bit, W7 64bit
Lucian
CLA
(3,162 Views)
Accepted by topic author LucianM
It is ActiveX server dll. Create constant, right click, Select ActiveX class, browse for dll
(3,127 Views)
I already tried to load the dll using an ActiveX container on the front panel but there is no browse button and I could not see it in the list and thought that this is not the way. Thank you Alexander!
Lucian
CLA
(3,076 Views)
