Hi there,
I need to create a DLL file uisng LabView7.0. The functions are: to configure, use digital IO lines & IO ports and ADC measurements for the NI PCI6025E card as per the hardware design.
I would like to know, if this is done, will there be any potential problem when this DLL is called from a VB or VC++ program assuming the system is alreaday installed with Lab View runtime engine. Other than the runtime engine, what other drivers or support programs/drivers would be required.
Your help is greatly appreciated on this.
Thanks n Regards,
Deepu.
